cademfjohnson »
https://forums.nicoclub.com/cademfjohnson-u152665.html
Mon Feb 15, 2010 6:09 am
my car has a horrible miss, almost a cut out, when i get into boost even just barely and at only about a third throttle. i can floor it and it will kinda choke its way out of it and move a little bit but its not moving near as fast as it should, obviously. its sucking gas and my plugs are all fouled. i swapped em out, same problem. i cleaned the iacv and reinstalled, checked for boost/vac leaks using carb cleaner, no luck. hoses still attached to fuel pressure regulators. im thinking this has to be an ignition problem or some kind of air metering problem. i tried resetting the ecu on a hope but it did no good. any ideas? i readjusted the tps too. its within spec now at .468 volts at idle. tried adjusting timing too with no luck there. idle is high at just over 2000 rpm, as soon as i plug in the iacv. unplug it, it idles normal at about 900.
overall it acts like an ignition coil problem, but seeing as these are coil on plug, its impossible all six went out at the exact same moment. ignition control module maybe? any ideas?
