Bad Pressure Plate? (fingers are flat)
caspers_240
Car: 91 s13 fastback
New ACT clutch kit w/ Fidanza Flywheel (flywheel ran 4 6mths with no problems). Deleted the clutch "sissy box," installed speed bleeder onto ~new slave w/ plenty of travel. no bubbles in the lines. adjusted the clutch pedal all the way in and out, clutch still would not engage. the fork had play too. i could push the fork with a small pry bar and the throw-out would finally touch the pres plate fingers.
so i pulled the motor out again (NEW RECORD: only took 1.5hrs. by myself! ). yanked off the trans and i noticed that the fingers on the pressure plate were completely flat. If the throw-out bearing would have hit the fingers, it would have pushed them onto the springs of the clutch disk. WTF? I double checked the part #'s w/ ACT and everything was correct. so i sent it off to have the P plate checked. Just wondering if anyone has had this problem, and if the pp is the problem. Starting to go through withdraws from not driving my S13.
180fan
Car: 89 fastback
first time I've heard of that happening on an ACT. then again I'm sure it's bound to happen since no product line is 100%.
caspers_240
BUMP: nobody have a clue?
Got the P. plate back from ACT everything checked out good. RE-REinstalled the engine, good travel on the (new) slave. still don't depress the ****ing pressure plate!!!!!^%$^%$%^$^%$&%$@%$@!#@^&**(&(*&(&*&*(&(**%^*&%$&^#$^%$#^%$#^%$#^%
pampadori
Car: 91 Nissan 240SX coupe
too be honest, they start out not flat. then as you tighten the bolts the fingers start to become flat.
