Jacototheb »
https://forums.nicoclub.com/jacototheb-u157973.html
Thu Dec 30, 2010 4:36 pm
I need some suggestions on what to do. My motor was recently rebuilt by someone who didn't know what they were doing. I didn't know this until after it was done... But the point is now it leaks a ton of oil. Seems like it's coming from the front main seal and is being thrown around(it has a new front main seal). But when I look under the car after being parked about 4 hours there is a softball sized oil spot on the ground under the passenger side of the motor. Oil is also leaking where the dipstick goes into the block. I heard that the egr delete can cause excessive oil pressure which would make the motor blow out all this oil? Possibly a pcv problem not venting the block enough? I have a catch can, but it's a simple one, no filter just a can with two hoses.
I really need some help figuring this out. I'm trying to sell the car... and I would like to fix as much as I can before it sells.
