bad o2 sensor, cold stall
roadboy240sx
Car: I like Nissans
bad o2 sensor maybe? any one got any info? i looked up cold stall but i coulndt find any thing. ill let the vid explain
http://www.youtube.com/watch?v=OZ0IWoS2wQU
Razi
Car: Moo
I doubt that's the O2 sensor's fault.Once my O2 sensor harness got cut, essentially running my car like it had no O2 sensor, I never had a stalling problem like that.
Have you checked your ECU codes yet?
roadboy240sx
Car: I like Nissans
Razi wrote:I doubt that's the O2 sensor's fault.Once my O2 sensor harness got cut, essentially running my car like it had no O2 sensor, I never had a stalling problem like that.
not yet im working on getting it in to use the scanner, proly some time early next week.
DRS_S13
Car: 1989 nissan 240sx coupe
Did you touch your maf?? Same thing with mine. Swap my maf and a somehow messed a wire up. Just un plug your maf and see if it runs in LIMP mode.
roadboy240sx
Car: I like Nissans
last time i unpluged my maf it ran like crap. its been a while i know my z needs a maf and it does sorta of the same thing when its cold, maybe a new maf?
this is on my 91 240sx, proly should have said that earlyer
DRS_S13
yeah we have the same motor. just unplug it and let us no.
Dazzla
Not the o2 sensor. My s14 does this but the revs will immediatly drop as soon as I start the car and it will die unless I give it a little throttle, then she has no problems
