Bad noise,bye $$
2KQA
Car: 2000 Q45 Anniversary 205k miles
I have a high pitch whine when the car is under moderate load acceleration. Showed up after an hour of driving the other night. The whine dissipates when you bring down the throttle. My gestimate is the output shaft bearing on the tranns.
Returning member new name thanks for the responses.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO!
At 205k miles the trans probably is on borrowed time if it's not been replaced... Can you tell where it's coming from? Another thing to consider would be the rear differential...
2KQA
Differential, I'll do some forum searching on that
Q451990
I'd check/change fluids and hope for the best. If it's not a really loud whine, it might be something that takes years to progress in to all-out failure.
My Frontier has exactly the same whine... I'm hoping fluid changes will help. Sadly, I've had the fluid sitting on a shelf for a couple of years and it hasn't sprouted feet and put itself into the truck yet. :confused:
Heath
2KQA
Yep,drive train does need a good fluid change. I noticed a carrier bearing in the torque shaft on some diagrams,bet that needs greasing.
