masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Tue Sep 28, 2004 2:17 pm
Sorry to hear about all that. My condolences.
The problem isn't really about age or even mileage for that matter. I have a 91 FB with over twice the miles yours has and, well, let's just say my repair list is significantly shorter. That's not to say I haven't had to fix stuff up... far from it; almost immediately after I bought the car, I had to replace the clutch, both of it's pneumatic cylinders, the water pump, all the filters and the brake master cylinder, as well as resealing the transmission. Needless to say, I was pissed. But since then, I've never had a major problem, and as you can see in my signature, the car still runs great.
My advice would be to sit on it for a while. Fix the transmission and see where you are by then. If you find that you're still having problems, you probably scored yourself a lemon and should ditch it. Is buying an S14 a solution? Some might think so, but not me. If you get one, you'll have to shell out a little extra cash (since it's newer) and count on the fact that when the car DOES get older, it WILL need fixing. It's inevitable. Financially, it's better just to keep your car and hope for the best.
