Bad motor mount! but which one?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
gekko668
I got a 2007 Versa and love it to death. As of lately everytime I stop at the stop light, the steering wheel and the passenger side would vibrate even worse when the AC is turn on. In park the engine is smooth, no vibration; when driving it is also smooth. I've baby this car and do maintenance regularly. The engine is smooth as silk and the transmission shifts great. I know it is a motor mount issue but don't which one is bad. From what i've been researched it might be a hydraulic motor mount but not really sure.
Any ideas?
Thanks in advance
ME18VERSA
Car: 09 nissan versa
89 5.0 mustang
with the car off and in park pop your hood and push the car back and forth you will see the motor move and then can see what mount is loose there is the one just on top very east to see of the not as easy to see . hope this helps
gekko668
Thanks for the reply. When you said it located east... do you mean it sit underneath the car?
gekko668
Ok so i just did what you told me and I do noticed the engine is moving slightly more toward the firewall (i dont now if it's normal or not) but there is a light clicking sound accompanying the engine when it's moving back and forth. The clicking doesn't sound metallic but sound like something either hitting or rubbing against each other.
ME18VERSA
89 5.0 mustang
sorry that was a typo that was supposed to say easy.
Camyman
Car: 2008 Nissan Versa 1.8S Sedan
do you also get a drop in RPM when the compressor for your a/c kicks on and the vibration is really bad during that drop? I think I may be experiencing the same problem you have, but mine seems to only happen when the compressor kicks on.
Return to “Versa Technical Discussions”
