Bad milage..no codes
WA261
Car: 96 J30
I am getting around 14mpg. I know this can be due to the knock sensor, but I have no codes coming up. Should I bypass it anyway and see how it goes? Also, is there a diagram of where it is located?
TIA!
yodawill2000
Car: 94 Infiniti J30
When you say no codes do you mean you actually pulled the codes or you have no Check Engine light ??
Leuthesius
Car: 1996 Infiniti J30 - Totaled by Hail RIP
1995 Smurfima - Blown Head Gasket 230k miles RIP
What's the car's mileage?
Do you smell gas?Is there lag time on acceleration?Is there any vibration?
I had been getting s***-tastic mileage a while back, as low as 15. No codes, but I DID have a minor fuel leak towards the back of the engine above the plenum.
Modified by Leuthesius at 1:03 AM 7/11/2009
WA261
Car: 96 J30
Ok, this is an odd one. After I posted this I went out and tried to pull up codes again. Well, I had the guys in the shop do it. Guess what?? PO325 Knock Sensor 1. and P0430 Cat eff below thresh bank 2. Why in the hell has this never come up before? The only thing that has been done since getting last reading on codes is that we changed my water pump.
yodawill2000
Did the engine get Hot with the old water pump ??That can crack a 13 year old plastic knock sensor.
WA261
Car: 96 J30
It was not getting hot, but leaking.
Do you guys know of a diag of where it is? I have an idea but I would like an exact.
yodawill2000
Under the Plenum A real bear to swap out.Some peeps relocate it to the rear of the engine.
Do a search for Knock sensor in this forum and you should find the thread with pics.
