Bad milage, CEL Code P0171
kd7skx
Car: 97 Nissan HB
Hi all,
So I am trying several nissan fourms to see if I can get any ideas on my trucks problem. I am getting 15 mpg and I know I should be getting in the 20's.
It is a 97 2wd 5speed 4cyl pickup.
So far from suggestions on other sites and googleing I have done this,
Seafoamed oil, put in vacuum lines, and fuel.
New sparks, wires, cap, rotor, oil, air filter, MAF and fuel filter.
I have checked with propane, several times, for vacuum leaks and have not found any.
I am thinking O2 sensor or maybe the temp sensor in the air filter housing now.
Any help or idea would be appreciated. Thanks
Saudade
kd7skx
Car: 97 Nissan HB
Thanks for the link, already know what the code is and what the definition is. Been trying to track down the culprit.
346ci
Car: 2000 Camaro SS
1993 Hissan HB X-Cab
1992 Chevy S10 4X4
What is your fuel pressure? Key on engine off should be 43 psi(to prime pump). At Idle should be 34psi.
