encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Sat Jun 28, 2003 4:22 am
Hey don't worry about it, you've helped immensely already. Take your time, like I said, it only happens occasionally.
Also today it did it again, I just held the throttle and cranked it for about 5 seconds straight and it started up, there was a puff of smoke from the tailpipe, so I assume that was fuel, couldn't be oil/coolant. So I assume it wasn't starting due to being rich and it just happened to work and the excess fuel was burned and that was the cloud.
Hopefully the problem is what you think it is. Any idea ballpark a new coolant temp sensor is? I may just pick one up new or at the junkyard for cheap to possibly solve the problem.
Again, thank you for the help.
