smokin240 »
https://forums.nicoclub.com/smokin240-u15929.html
Fri Oct 29, 2004 3:40 am
I have a DOHC KA and when it warms up after about 2min the engine will lose ALOT of power and I cant press the pedal down pass half way or it will bog down real bad. Also, when im below 3000rpm or above 3500 its even worse. But anyway someone told me it was the mafs also and I relaced that and it didn't work. Also tried the plugs, rotor, coil, wires, vacuum leaks, acelerator node resitance thing :-/ and a couple other things. Ive had about 5 mechanics look at it and ran codes on it as well. I've finally came to the solution that its my catalytic converter clogged up because the guy who had it before me put low grade gas in it all the time plus it has high miles. I still havent gotten around to testing it or anything but im pretty sure thats what it is because someone I know had the exact same prob and said he fixed it with a new cat. anyway if you end up trying this out let me know if it works
