Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Jun 28, 2006 11:25 am
You can check the MAF wires for continuity to the ECU and to ground. That should get you half way there. Did you extend the wires at all yet? If so, did you shield them? I know these probably won't have an impact on the way it is running right now, but I'm just making sure you have that in mind.
I have also heard that if you do not have your neutral position switch wired up properly, the same symptomes will happen. I.E. not being able to rev the motor. That is hearsay so I am not positive on that one. I'd check your MAF wiring according to the FSM first, then report back to us.
If everything checks out and it still runs crappy, finish the swap first
