Bad low end throttle response\
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
My Q runs pretty good, but the low end throttle response sucks. Ones it gets past about 3500 it takes off and is great, but I can BARELY even get the tires to squeal. I was thinking of replacing the spark plugs next weekend, and I want to know if there is anything else I can do while im in there! I know it is supposed to be better than this, and I have never even got it to spin the wheels or burn with TCS off.
Q45tech
4 valve per cylinder engines produce less low rpm torque than two valve engines because everything [air passages] are sized to work well at 6,000 rpm.
Kind of like a seesaw with the pivot point at 3,000 rpm...improve the top hurt the bottom.
274 cubic inches is a pretty small engine for a 4300 pound car yet by 2,000 rpm it has enough torque to run 60 mph on a level road with AC on.......pretty amazing if you ask me.
To improve [stay the same] city mpg [with extra weight of 94] the transmission gears in 1st and 2nd were reduced by 5% [on average] and the engine barely meets published numbers [due to emission redesign]. [90-93 typically exceeded published torque number by 5%]So a 94 is at a 10% total disadvantage compared to a 93.Some how the tweeked the tuning to still function at 2,000 rpm.
Short of changing the rear diff gear set to 4.083 [15.4% higher] not much one can do other than maintaining what you have to highest standards.
Modern 5 speed AT [M45] have a total gear multiplication in 1st of closer to 12-13 compared to your 94Q's 9.45.......this is 30-35% more rear tire spinning power for exactly the same engine output in 1st gear.
Anyway spinning the rear tires is counter productive in acceleration, what you want is 1% less that the tire spinning power.
elwesso
2007 BMW M Coupe
It probably has a dirty TB and plenum also, but it seems like it doesnt have any power below 3000 RPMs (my aunts 3.1L grand prix has more).
sultan
this probably is not the problem, but how tight is the throttle cable? make sure it doesn't have a lot of slack in it, but don't tighten it so much it opens the throttle.
QShip
Q45tech wrote:4 valve per cylinder engines produce less low rpm torque than two valve engines because everything [air passages] are sized to work well at 6,000 rpm.
I had wondered that myself. Thanks Dennis.
Wes - I have the rearend swap available that Dennis speaks of... E-me if you're interested.
4.08 is a direct swap and is about a 5 hour job.
Fred has it in his Q as well.
Q45tech
Don't go messing with throttle cables slack is good! Seen too many screwed up by owners this way!
elwesso
2007 BMW M Coupe
How much different is the 4.08 rear end?
So what do you think my ulitmate problem is? I know my spark plugs havent been changed in at least 80k miles, so I would assume other things like a rail flush, differential gear lube change, brake and PS fluid hasnt been changed either. No work next weekend, so its tuneup time!
Q45tech
Changing the diff ratio is ALMOST like adding torque to the engine AT least in 1st gear...........a 15% extra multiplication will deliver at least 14.5% more pound feet at the tire road interface.
292 x 0.787=230 lb/ft x [total gear multiplication] @ 4,000 rpm divided by 2 [the power goes half to each tire].
The total gear multiplication 9.35 goes to about 10.8 and the rpm per 10 mph goes from 1267 to 1457 so max speed in 1st drops from 52 to 45 mph.......better but not ideal since 35 mph would be best for zero to 30 mph acceleration test.OR spinning rear tires at launch.
Problem is you cannot launch at 4,000 rpm where torque is maximized, since the torque convertor stalls at 2,200 rpm.
So if zero to 30 mph takes 3.8 seconds stock, a 4.083 diff might improve it by 0.1-0.2 seconds.
crubio
Car: cars, karate, reading
I would change the fuel filter and breather element. It could be as simple as that. :)
crubio
elwesso
2007 BMW M Coupe
What is the "breather element"; air filter???
The fuel pump was recently replaced, so i would ASSUME they would have replaced the filter also.
Q45tech
Never assume anything about automotive service. Failure to change [every 15-20k] under hood [after pump] fuel filter is a source of diminished pump life.
The filter is small and the amount of microscopic dirt in 1,000 gallons of fuel can be large. [or not-depends].
PalmerWMD
Car: 2004 350Z
is your t-stat original?If yes you may be running too cool? (engine stays in warm-up mode= less power)Or too hot (engine reacts to perceived overheat=less power)?
The above may not always be evident in your temp gauge.
Fred...:)
airman
Car: q45t
palmerwmd wrote:is your t-stat original?If not you may be running too cool? (engine stays in warm-up mode= less power)Or too hot (engine reacts to perceived overheat=less power)?
Fred...:)
What is the t-stat change interval?
DAEDALUS
Car: 1990 Infiniti Q45
I don't think there is one listed in the manual...maybe 60k? Based more on the experience of shops/techs. Even then, I'll bet lifetime varies quite a bit. There is a procedure for checking it out of the car, but for an $8 part, once you remove it you may as well replace it rather than run a boiling water bath test.
elwesso
2007 BMW M Coupe
My T stat is origional, Ill replace the it too. Do I have to drain anything besides the radiator so I dont unleash the flood gates?
Also, where is the fuel filter. I dont think it is in the same spot in my 94 as it is in the 90 (i have a 90 service manual).
Q45tech
Same spot same filter 90-96Q
elwesso
2007 BMW M Coupe
Thanks guys!! I found it may be easier to locate the fuel filter if you looked in the right spot!
