Mint Q45A »
https://forums.nicoclub.com/mint-q45a-u39580.html
Tue Dec 18, 2007 2:32 pm
Can a bad KS affect the startup - making it harder to start the car, or the idle - making it high/unstable?
I understand the KS function is to detect knock and signal the ECU to adjust the timing to "correct" it; in the Q it is able to do it for each bank of cylinders, individually. This I assume is more prone to happen when you are accelerating....but not sure if it also works at startup or idle or even, decelerating.
Just curious...
