kaizenveryfast »
https://forums.nicoclub.com/kaizenveryfast-u33535.html
Fri May 23, 2008 7:49 pm
I tried to smog my car the other day and failed for running rich. I pulled code 33 and 34 from the ECM, O2 and KS. Before I shell out for a new knock sensor, could it be triggering a code because of the noise caused by the timing chain guides? I have not got this taken care of yet, as it is only a TSB and should not be a serious fault to require a recall. The KS is kind of expensive and hard to replace and I need this thing to pass ASAP. It runs great as it is, and I get a solid 24 mpg on the highway, I'll be on cloud 9 if I replace these 2 and it starts getting even better mpgs. I appreciate the help.
