aurora61 »
https://forums.nicoclub.com/aurora61-u42830.html
Tue Mar 18, 2008 11:12 am
my car has been running bad...runs as if it has a bad ground or something.
I noticed today that one of the injectors was leaking...which i believed was the culprit for my car running so bad. so i changed all the o-rings and no more leaks, but the car still runs horrible.
I figured out that holding the injector closest to the front of the car in a certain/exact position makes the engine run normally again. In order to position the injector that "perfect" way, i pivoted and moved it til the idling engine sounded normal again.
I tried putting the injector in that position and driving, but the engine vibrations repositions the injector. For now, i ziptied the injector in the "perfect" position, but its just a temporary solution...
Is this a bad injector or is there another problem?
p.s. its a sohc
