You replace the [underhood] injector fuse with a loop of wire and clamp the amplified current probe on the loop. Attach probe to scope and trigger scope from #1 injector.
All injector receive constant +13 volts in parallel after fuse, the ecu switches the ground lead to ground via individual transistors.
8 nice 45 degree ramps [with a little ~ {squiggle} at 55- 66% of peak current] as each injector lifts the pintle then staturates.
The inductance changes as the pintle moves up.
The above test is more precise as you can see all the pintles lift [electronically] [any out of time - sluggish opening]......early lift weak internal spring on solenoid, late lift - varnish or shorted turn.
Obviously all 8 should draw the same peak current [1 ampere]. High resolution probe/scope would allow the after current cut ringing to be visable.
http://www.lindertech.com/newsletters/n ... chives.htm
