BOUDREAUX wrote:Also, how do I determine what color I need to buy? How difficult are these to replace?
It's your lucky day. Injector #8 is one of 3 that are very easy to get to without removing the plenum. Rather than give you 101 tips on how to properly remove and install an injector, you should do a search on injector removal. Take 15 minutes and read the posts that come up and you'll feel confident taking on the job.
As far as injector color there are many here who say it will make no difference and just buy a "no dot" injector. But since it's #8 you should be able to easily remove the connector from the injector top, see the dot and then order up your injector ahead of time. It will be underneath the connector and be very faded after 15 years. I've pulled white dot and yellow dot injectors and they were both difficult to see.
Sounds like you may have a bit more going on than just one bad injector. Have you pulled the codes on the ECU? Any corrosion on connectors?
Good luck with the gremlins.
