Could definitely be an injector. Have they been replaced? Less common possibilities might be a bad coil pack or ptu.
You can narrow it down to one cylinder by doing the power balance test. Search on it, you will find lots of information and how to do it
Also, you can check an injector by measuring the resistance across both pins. I don't know the spec off the top of my head, but it's easily found with a quick search as well! Try, "ohming injectors"
