When I checked the car outside the dealership (they were closing that day) I was more concerned on dents and scratches in the body. I did not see anything out of the ordinary.
Went home and do my work and home routine. Yesterday, June 6 I was trying to wipe thise dead bugs stuck on the front bumper and I noticed that the bumper cover vibrates too much when I tap it with my hand. Somethinf that I never seen before.
The front bumper as I remember is tight and solid if I had to hit it with my hand. So I investigate more on the problem and found all these issues.
So here are all the issue I found .
1) Loose/vibrating front bumper. (Video below)
View My Video
2) 4 broken upper front grill. (Below)
3) Missing screw on the wheel well front trim and bumper. (Below)
4) Upper edge of the front grill is cracked/broken. (Below)
5) Loose wires behind the front grill. Wires should be attached to the hole above.
6) Very minor , but how much is this tab worth? It is broken with out any tightening capability and just put in the hole. (Below)
7) Screw front undercarriage cover is very loose. Not a big deal, but this minor stuff tells the quality of the service dept. performing the work.
8) found this on top of the brake cylinder cover.
So picked the car up on June 2 and found this issue on June 6, about 4 days interval. How are you guys going to tackle this? I emailed the service manager and attached all these photos with descriptions. I also included a one minute video tapping the front bumper cover.
If the tech could make these issues were a customer can see it, how much pride in his work you think he did on those parts he replaced (timing cover chain leaks warranty work) that a customer won`t be able to see?
