itsnever2fast »
https://forums.nicoclub.com/itsnever2fast-u43601.html
Sun Jun 24, 2007 12:56 pm
STOP EFFING WITH THE IGNITOR. if you aren't getting inj pulse its not the damn ignitor. when you have the key on run, and you unplug and then plug in your Cam Angle Sensor does your fuel pump kick on? if you have your CAS out of the block, turn the key on, unplug your fuel pump fuse, and turn the CAS shaft by hand you should hear the injectors clicking away, if they aren't your CAS/ECU may have issues, if they are working, check for spark the same way, remove one coil, turn CAS rapidly by hand and check for spark. no spark... check power to ignitor and coils
