afmafia wrote:did u ever figure out what the problem with your car was ?? honestly i dont think your turbo is shot . also where is your bov located on the driver side or passanger side of the car ??
I think its the turbo due to fact that there is no oil in the coolent and no coolent in the oil. It does not overheat and only smokes when coming to a slow stop and while idling. It does not do it when its cold only when its warm. Also compression is good 162 in all cyl and not a drop of oil or coolent is visable anywhere around the head or block. Took the cam cover off and the oil is normal color.
I figured it was the turbo from talking with S14MARKSR over AIM. When I installed the cams, headgasket and greddy valve springs I errored and clocked the intake cam 3 teeth advanced so the exhaust mani super heated at idles and probably overheated the turbo too fast causing the trust bearing seals to go bad. Plus the car sat while I was on vacation back in June for 3 weeks with the exhaust fill of water half way up the downpipe. The water was from a flood that happend the 2nd day I was gone on vacation, thanks to the AF for plugging our storm drains ... but thats another story....
Anyhow after I fixed the cam timing I took it out let the motor idle at 1000rpm for 20 min and then 2000 for 10min to break in the head gasket. Then I took it out on the highway and holy crap it pulled like hell... was like a totally different motor...really put a smile on my face. Then I slowed down on the offramp and came to a stop at the stop sign and wham smoke screen.
