To start off, I searched that's where i got most of my info from.
Car was running great. Started it up one day and had a bad idle. So i changed spark plugs, wires, cap and rotor, on changepulled the iacv and cleaned it, no changeBought a new (used) iacv and installed it with a new gasket, no change. resautered the connections to the maf, O2 and my SAFC,cleaned and tested the maf with maf cleaner,Did a boost leak test and sprayed carb cleaner all around the intake (no leaks found)tested temp sensor, test ground to chasse, tested tps.Found that the first injector was a little loose so i pulled the fuel rail and tested to see if i had a leaky injector, nope!!!!!pulled the injector out and changed all the o-rings (just in case) NO CHANGE!!!!
here's a little vid of it running. It seems to lean out and the RPM's fluxuate up and down when it happeds. It does it when it cold or hot.
http://www.youtube.com/watch?v=wei9daPR-V4Oh sorry , my setup:
Garrett T3/T04E TurboJGS manny and down pipeGodspeed FMICCustom 2.5 IC piping555 InjectorsZ32 mafN1 3" catback with test pipeTurboxs BOVEnthalpy tuned ECUNoe SAFCRunning 12 psi
Modified by esahuque at 6:49 PM 9/11/2007
