slipnfall wrote:Hi there, I'm curious to hear about your problem with the boucing timing. I had a similar problem(on an S13 though), and am now wondering if it's my cheap cap/rotor. Can you describe exactly what the timing was doing when you were looking at it w/a timing light? You can email if you don't want to stray off topic.
Are the 7E spark plugs a step colder? If not whats the diff? Also what MSD ignition setup did you have?
Thanks, glad to hear you got it working.-Jamie
Well, when i had the timming gun flahsing over the pulley, the 20 degree mark would not stay under the needle. It would bounce from like 17-23 degree's back and forth..!! Normally, when u check the timming, the timming marks are supposed to stay in one place, then u adjust the distributor and to move the timming mark to where u need it, but in my case, it would not stay still...
And yes the 7 heat range plugs r colder and we use them for higher boost levels...
The msd box was just the box alone, no coil. All i did was modify the distributor (cause its an internal coil) to accept the msd..
