I got one from work, but thanks Inshan! I went into Nissan earlier today and set the timing to 15 degrees BTDC
update on the engine progress: runs like a scalded cat... but only after a week of crap :pface
so today I played around with the maf (with Dee's help on the phone) and was able to determine it was causing my problems... If I unplugged it, it idled perfect, but obviously wouldn't rev past 2k. we had it directly mounted on the front of the turbo. Dee mentioned that if its too close to the turbo it can't get accurate readings, so I got some pipe, and moved it about a foot away.
Still idled like crap. Drove it around the neighborhood, and it runs decent above idle, but still the same bad throttle response and poor idle that has plagued it from the start. I then remember a friend of mine down the street with a CA18DET just upgraded to a z32 maf, and has an extra CA18DET maf laying around (his name is Mike, and he use to post here alot, CA18_RS13 or something like that)
so I drove down the street and got his maf...HOLY CRAP IT RUNS GREAT! Idles rock solid at 800rpm, no hesitation, and woooo does it go!:D I still have a massive exhaust leak where the downpipe meets the cat, but I'll be making my exhaust next week sometime, along with my fmic piping, so I'm not too worried about it.
I'm hitting about 7psi max boost right now, BUT its still idling at 16 or 17 psi of vaccum. When I let off the throttle and cruise, it goes to 20 psi, but at idle it bounces between 15 and 18. I think I have a leak somewhere, but I've been looking for hours and just don't see it! I even pulled all my intercooler piping off and re-did it, with no change. Any other suggestions?
I need to upload these pictures. I have so many its not even funny:)
Sean
