bad idle help plz ; )
davidfrost240
Car: racing
i have a 92 240 se and i am having trouble figuring out the idleing problem it has it gets bad when the electrical load is heavy for instance when i turn on the lights it drops or the breaks it drops. or on deacceleration it will drop and is only stable and it is sitting.
could somone plz give me some pointers on what the problem is thx.
GodDrivesA240sx
Car: 1995 Nissan 240SX
davidfrost240 wrote:i have a 92 240 se and i am having trouble figuring out the idleing problem it has it gets bad when the electrical load is heavy for instance when i turn on the lights it drops or the breaks it drops. or on deacceleration it will drop and is only stable and it is sitting.
Hmm...maybe a bad ground? Are your battery terminals clean?
Aries
Car: LT1 240SS
GodDrivesA240sx wrote:Hmm...maybe a bad ground? Are your battery terminals clean?
Exactly right.It's a bad ground somewhere between the battery and the frame.OR, it's the power lead from the battery into the car.Check your connections at the battery first, then start tracing the wires back into the car. (Ground wire first)
GodDrivesA240sx
yizeah. I punked that question
:D
Aries
Car: LT1 240SS
LOL, my 95 base model has this same problem from time to time.It vibrates bolts loose about every 15000 miles.
Just keep them all tight, or use some threadlock and it'll all be good.
