Bad idle and sputter at WOT
UsedGoldfish
Car: 1994 Nissan Altima 5spd
I have a 93 240 with s13 blacktop that when I get to full boost it cuts out and makes this bubbling sound but boost doesn't drop... And if i stay on the throttle clears up a little bit after around 5k or so. Things ive checked and/or replaced...
ECU - Checked fault codes got a code 55
Spark plugs - replaced all 4
Coil packs - checked and replaced one
Fuel filter - replaced
Fuel injectors - checked
MAF - checked and cleaned
It idles bad runs good until around 3-4k only at WOT or close to it. If needed I can video tape it and post it tomorrow after work
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Do a boost leak test and gap plugs to 28-30. And get back to us.
UsedGoldfish
They are gapped at 32 is it really that much of a difference but we did a boost leak test and no leaks
Edit: I regapped all the plugs and nothing changed...
compactfean
daily
32 is good for lower boost. What's your fuel pressure at and how is your maf/intake setup
