ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Sun Apr 16, 2006 4:39 pm
Tryin to put my auto 92 s13 back on the road and am having some issues with the idle. I've been modding it a bit first so i'll tell you guys to help narrow it down... put a short ram air intake, new exaust, cat, headers, plugs, wires, regrounded everything, cleaned up the engine bay a bit, cleaned out my MAF and my IAA, i also took out all EGR related items and put a plate where the egr used to be, plugged up all the vacuum ports, and put a breather on my valve cover and IAA tube. I've put my car in neutral, and had the TPS disconnected to adjust my idle, but even then its goin up and down between 600 and 700. then when i connect everything back and start up my car it is at 1500rpm or more for a few seconds and then drops low enough to dim the lights which is around 300 and then pops up to 700ish and goes up and down between 600-700 again. If i rev the engine I hear it bog a little and i hear the pops from backfire, then the rpms dip low again and settle back between 600-700, sometimes if i rev it the engine completely stalls out. I've ran the car with the MAF disconnected and it idles a little better but if i rev it to the 2500 limit, when it goes back to idle it dips to about 500 then back up to the varying 600-700 idle. The gas in the tank is the same gas from months ago, but before the winter i put treatments in it to prevent the lines from freezing and to prevent it from gunking up...but its still old gas, could this have anything to do with it? Any help is greatly appreciated.
