Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri Feb 11, 2011 9:01 pm
Maladjusted TPS can cause idle issues.
ECU codes, just peel the carpet back in the passenger floorboard from the top, take out the 4 10mm bolts holding the plywood floorboard in, and then you have access to the ECU.
Turn the key to the "ON" position, but don't start the car. Then turn the small slotted potentiometer with a flathead screwdriver fully clockwise, wait two seconds, and turn it counter clockwise. The Check Engine Light will flash codes. Long flash is first digit, Short flash is second digit.
So **Long long, long, short, short** would be code 32, or EGR.
You can google Z32 ECU codes for the full list.
