Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Nov 21, 2005 11:47 am
No, it's a deal on the Nissan ECU, called Limp-home mode. If you have an MAF or TPS fail, it will not let you drive above 2500RPM, then it cuts fuel and you fall back down. If you mash the gas at 2.5K it feels like it is flooding bad. It is telling you there is something wrong enough that it cannot properly control the engine, but runs on a baseline to get you home. Had it happen to me when I was dumb enough to cut a scoop above my MAF and got rain in it. It was a noob mistake for sure. But that is something to think about. You can read up on it in the FSM. On the 240sx forum you can download either an S13 or S14 FSM, and it's a sticky, so it's easy to find.
