bad hesitation around 2000 - 3000rpm
ns-chud
Car: 1990 240sx
my car has a bad hesitaion threw 2000-3000 rmp i would like to know if any others have / had this problem and how they fixed it.
thanks for the help
chad
180fan
Car: 89 fastback
does it go past 2500-3k rpm?
nightkid86
Car: 97 S14 SE
My car used to have hesitation between 2800 and 3500 - the pedal had to be pushed more, and the engine got louder, when I put in a new transmission it fixed it.
ns-chud
Car: 1990 240sx
yea the car goes past 3500rpm
new_to_drift
Car: 89 240SX coupe
my car was having the same problem.But it only does it when the car is warmed up, i think mine might be a o2 sensor.I will find that out tomorrow, im replacing it.Ill let u know.
SumoBrian
Car: 240sx
maybe the egr too?
tiger
i think it's your MAF... check your ecu for codes to be sure. Does it sound like a WRX when you rev it?
DriftFactory
Car: Evil S13
Is your clutch slipping, that RPM band has quite a bit of torque. Otherwise I would check the air fuel mix and go from there.
ns-chud
Car: 1990 240sx
well im changing the fuel filter and im getting new injectors plus some others ill c how that goes
tiger
hey dont waste all of your time/money buying new injectors... geez... why don't you just make sure they are working before you go through the trouble of yanking them out? I can tell you how to do this. Check your ecu for codes. U gotta troubleshoot, it's the only way.
new_to_drift
Car: 89 240SX coupe
if your maf truly was havingproblems.u prolly wouldnt be able to rev past 3k.check your o2 sensor.does this problem only happen when your car is warmed up?if so then it maybe your o2 sensor cuz it maybe wouldnt be sending your ecu the signal to make the fuel more lean
S14toRPS13
I had the same problem. Turned out to be just the fuel filter, but I see you're planning to change that out already. Hopefully that'll work out for you.
andyman61
Car: 1989 Nissan 240SX Hatchback
i had a similar problem with a car that had been sat in a garage for 3 years. drained the old gas, put in new gas with STP fuel system cleaner, and a new fuel filter. i doubt this is your exact problem, but it could be a bad batch of fuel?
also, same car wouldn't idle for **** after we got it fired and revved poorly until we realized we had taken off the air box to poke around at fuses. once that went back on, the car was rev-a-licous. maybe the sensor in the fuel box (air temp?) ate ****.
