Bad Gas mileage
Dinosaurdriftteam
Car: 90 Nissan 300zx
I have a 90 300zx and it is getting really bad gas mileage. I checked the codes and it said it was the o2 sensor. I changed the o2 sensor and it is still reading the same code 33.
Any sugestions?
twinturbozxtacy
Car: 91 tt
there are two o2 sensors, do both at the same time. then start with a tune up(plugs, fuel filter, air filter, oil change) they only get around 20 mpg, its a sports car...
Dinosaurdriftteam
I will change the other o2 sensor. and will give it a tune up. I am getting about 9 mpg so I should be getting twice as much.
twinturbozxtacy
Car: 91 tt
ha ha yeah 9 is bad, usually what i get when im flooring it all the time. whats the mileage on the motor? you should also check the compression.
Dinosaurdriftteam
The motor has 84,000 on it and I will try to check the compression
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Yeah 9 mpg is like a Hummer H1 on the highway lol
What brand of O2 sensor did you use? If you used cheap ones they won't last long -- either get OEM Nissan ones or Bosch (real ones). I put a pair of some no-name brand ones in and they lasted about a month before the codes came back. I put good Bosch ones in and haven't had a problem since.
Other causes of high fuel consumption can be bad coolant temp sensor (cheap, like $23 on Z1), fuel temp sensor (also fairly cheap), bad pcv valves, old spark plugs, incorrect ignition timing, etc.
ta0sum559
Car: 1992 300zx tt - bone stock
2006 Evo Mr - 400whp
1995 integra - gas saver
2007 Yamaha R1
1974 Datsun 260z with 350sbc
a nice tune up with some weight shedding should help.
