Pollarican »
https://forums.nicoclub.com/pollarican-u47746.html
Tue Sep 26, 2006 2:45 pm
Try swapping the relay that controls your fuel pump. If you are running rich, it could be due to your relay getting stuck and your fuel pump getting stuck pumping rich gas like it should do to prime your car when you start it. I had the same symptoms with a 91 Ford Explorer my family had. I swapped the fuel pump and everything and in the end the main cause of the problem was a 15 dollar fuse relay that jammed.
