GEO wrote:chillmieste wrote:I just finished installing evrything about a week ago. I was going on one final tune on the highway for my hi throttle points on the safc. Got it tuned perfectly 11.8 12.2 afr. I pull up to a stop light and ther car started to put put like a go kart. Im like my car doesnt usually sound like this. I pull back into my shop and oil all over the valve cover, it looked like it all came out of my valve cover breather. Car felt kinda sluggish, did compression test cylinder 1,3,4 80 psi...... After all my hard work the fukin gas at this mobil station was s***. after this happened i was talkin to My fabricator, he was like man that gas station made his scion knock like crazy. he put in fuel stabilizer and went to another gas station and the noise went away. Im assuming my ring lands cracked pressure built up in the cracnk case and came all out my valve cover... Im in south florida in pompano. dont know how ur mobil gas stations are in other stated or around florida, but BE CAREFUL WHAT GAS UR PUTTING IN UR CAR!!!
11.8 - 12.2 is NOT safe ...
you should have been more in the 10.8-11.2 range at WOT... Also what was your timing and spark plug depth?
Im sorry but 10 A/F is WAY to rich. 11.5-12 is perfectly fine to tune on. I tune all my cars to this area. anything less than 11s and your just wasting fuel. Maybe on a big HP build Id stick closer to 11-11.5 but Ive tuned many cars to 11.5-12 and they make great power, still running fine to this day (over 3 years on some of the tunes), and they dont detonate at all.
Also addressing what AZHitman said. I dont totally agree that the SAFC is crap its just no the best option for larger power motors. Especially if you build the motor. For your standard KA-T or slightly higher modded KA its ok.
The SAFC does fool the ECU and this does make timing issues but only for cars running larger injectors such as 740cc (which is the theoretical limit of the SAFC).
Better explination of what it does, the SAFC intercepts MAF signals and changes the output voltage to change the amount of fuel added, well the thing you have to realize is the ECU also uses that MAF voltage to tell the amount of timing to add.
Kind of hard to see but if you look across the top, the "LOAD" is what the ECU sees from the MAF. As you pull voltage to get less fuel the ECU reads from a different cell. This directly corresponds to the timing map. It reads the exact same way, the problem is though on most factory maps the less load (MAF Voltage) the MORE timing it adds. So when you use a 740cc injector you have to pull a lot of fuel = a lot less MAF voltage ("LOAD") = MORE timing.
MORE timing = Detonation
