Bad Fuel Regulator
.::94Q45::.
Car: 1994 Infiniti Q45
where can I find the fuel regulator on a G50 Q45?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
There are so many things that regulate the fuel I wouldn't even know where to begin.
Do you mean Fuel Pressure Regulator? if so then look near the #7 injector. I don't think Dennis has ever seen one fail though. They are filled with Japanese (JDM) air when made, a little JDM freebie that comes with the 50K car I suppose.
That is where you test for "Vacuum Pressure" which should be at least 18" HG (Inches of Mercury)
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Take a look at pages 6 and 14 from the EC Section of the FSM:
http://www.nicoclub.com/FSM/Q45/1994_Q45/ec.pdf
.::94Q45::.
Im not sure what regulator it is, but my q45 somtimes idles find and somtimes it will go from 1000 rpm to like 500 rpm and then go back up.
any ideas what this could be?
.::94Q45::.
where is the fuel pressure regulator?
near injector #7?
goody90q45
Car: 1992 Infiniti Q45 (sold)
It's under the plenum attached to the fuel rail just past the #7 injector on the driver's side. It maintains fuel pressure to the injectors in the 40'ish psi range and bleeds excess pressure back to the fuel tank.
goody90q45
.::94Q45::. wrote:......but my q45 somtimes idles find and somtimes it will go from 1000 rpm to like 500 rpm and then go back up.........
If this happens in the 90-96 Q it's the mass air flow sensor or a dirty MAF connector causing the problem. Have you cleaned your MAF? Any corrosion on the connector? Is the check engine light on? Have you pulled ECU codes lately?
.::94Q45::.
Ok now I have an Idea where it is...yes I have cleaned the MAF sensor and connector and yes sometimes the check engine light comes on...havn't pulled ECU codes yet though.
Q451990
Definitely check that code before you start swapping parts. The MAF is certainly the most likely culprit. They will tend to fail internally as well, so don't rule it out just because you cleaned the connector and sensor.
Heath
