bad experiences from drilling rotors?
mt05
Car: 240sx
Hey, so to everyone that has had their rotors drilled to fit a specific setup, in my case drilling the z32 rotors to make fit on my s13 240sx. i know alot of guys drill the 4 bolt pattern into the z32 rotor but i would like to hear some experiences afterwards? alot of people tell me its a BIG no, and others say its perfectly fine, heck circuit sports sells a rotor with both the 4 bolt and 5 bolt pattern on it from factory....anyways experiences? anyone?
s13rb25det
Car: 92 240sx w/rb25det
I had 350z rotors dilled for 4 lug and it was no big deal it cost about 50 bucks.
ashibah83
Car: 93 SUPA BLACK COUPE
as long as the lug holes are centered and the rotor runout is till good i dont think there is anything wrong wih it, if you get the holes off center then bad things will happen
94_240sx
Car: 94_240SX
ashibah83 wrote:if you get the holes off center then bad things will happen
If holes are off, rotor wouldn't go in. Rotor is hub centric, so if drilled holes are 1mm off, rotor wouldn't go in. It's okay if holes are slightly larger than the stud. Once wheel is on and lugnuts are tightened, there'll be no play whatsoever.
ashibah83
yes, but isnt the hub diameter larger for the 300zx than it is for the 240???
94_240sx
Car: 94_240SX
ashibah83 wrote:yes, but isnt the hub diameter larger for the 300zx than it is for the 240???
They are exactly the same. Here's redrilled z32 rotor on my car. Perfect fit and car doesn't shake or anything at high speed.
ashibah83
k , i thought they were different sizes
btw, clean car......and Stance Gr+ pro's=
Stripes
Car: hatch, coupe
How do you like those stance coils? I've heard mixed opinions but I'm looking for something new pretty soon.
94_240sx
Car: 94_240SX
Stripes wrote:How do you like those stance coils? I've heard mixed opinions but I'm looking for something new pretty soon.
I love them. Sometime I forget that I have coilovers. Very comfortable yet controlled stiff. If I have to buy again, I'll buy GR+ Pro for sure.
S133P3R
Car: 1989 S13 240sx
if possible, use a drill press... i drilled mine by hand and it was a PITA X3 to keep the drill level. also the shavings, even though swept up, still left a ssweet rust stain on my driveway the day after. i recommend using a few bolts to drop in and hold the rotors aligned. also, they need to be tapered from the back for the wheel studs... have fun!
