Thoughtful_One »
https://forums.nicoclub.com/thoughtful-one-u29843.html
Fri Feb 02, 2007 10:50 am
The car is a 1992 with a KA24DE, all stock. At idle, I have the infamous chain rattle, and the rattle is very frequent.
When revving in neutral, all is fine until 2800 RPM. Pass this point, there is a secondary sound they is louder than the engine itself. It sounds like dragging a motorcycle chain across a piece of plywood, and it's intensity increases as the RPM increases.
The oil level is good, but I'm not sure about the pressure. The oil itself seems VERY thin (I used 10W 40 when I changed the oil three weeks ago). The coolant in the radiator looks fine, no discoloration, or film indicating headgasket issues.
The motor itself *really* lacks power. The idle is pretty solid at 800 RPM. At WOT, the car seems to bog. When I pulled codes awhile ago, code 11 came up, indicating Cam. pos. sensor. When I looked in the FSM, it said a whole host of things could cause that to happen.
What is causing this incredibly loud grinding? I don't want to just remove the guides because they are not causing the grinding. I really need help.
