Bad Electrical Problem
USEDTOHAVEA240
Car: skateboarding
Hi I have a 1995 Nissan 240sx and recently while trying to install a new cd unit I crossed some wires and now the only electrical components that work are my power door locks, dome lights, and clock. The car will not start. I checked and replaced 2 fuses and still nothing works. Any help is appreciated.
bangstanger
Car: 91 240SX Hatch
do you know which wires you crossed...ie color or plug...also have you checked your fusible links on the pos batt cable?
USEDTOHAVEA240
Car: skateboarding
I have not checked the fusable links thanks. And the wire was a ground wire and a red 12v wire i belive.
bangstanger
Car: 91 240SX Hatch
Well I have a 91 and dont think they are the same..but I looked at my wires for the stereo..and I cant find anything there that would cause that kinda prob...unless maybe the mem wire (constant 12+) could do it.. I would be sure to check those fusible links and also it would be a good idea to look at all the ones that may be in the box by the batt and also possibly by the air filter although I believe those are only like fogs and ac and such...I am sorry I dont know enough of the particulars of your car to narrow it down much...
USEDTOHAVEA240
Car: skateboarding
thanks for the help! Will be working on fixing it tommorow.
s13sr20chris
in theory there must be a fuse/fusible link blown somewhere. did anything change after replacing the fuses?
