bware113 »
https://forums.nicoclub.com/bware113-u38173.html
Tue Sep 29, 2009 8:11 am
Ok lets see here...from the start. On Saturday I decided to sit and do a brake job for my baby; turn rotors, replace pads, re-lube, etc. Get the car up and off the ground, on jack stands and remove everything accordingly all except one rotor on the front pass. side that apparently loved my hub and couldn't imagine being separated. So I put a towel over it and give it a few wacks over the course of like....20mins!!! It came loose and finally took them for a turning and to pick up my pads, during which time it rained like the d!ck! Finished the job in the rain and took her for a drive...it stopped raining immediately after finishing ...
Problem #1Now I'm getting a mean shake in my steering wheel only when driving at speeds between 40-55ish MPH. Never while braking. Checked and got a full alignment and everything is fine there but the problem still exists. Replace the tires assuming they may be the culprit and still it persists...IDEAS?
On to the next yesterday morning woke up attempting to change plugs and wires, elementary work. Did the plugs first and got 3 of 4 plugs done. On the 4th(back of the engine) the S.O.B. breaks in the engine, enough to keep me from getting it out...UGH...but not well enough to keep the wire from going on so I put the old wires on and sputter and jerk my way up to BIG 10 to avoid any problems and get it done. $90 later for them putting on the items I bought, 1 plug 4 wires, I head home and prepare for work. Upon getting ready to leave Little Ms. Piggy won't even idle... ....Start:DIE...Start:DIE...WTH is going on? So I keep the car running by giving some gas...all seemed well at about 2.5k or higher so I race back up to BIG 10 assuming it my dist. cap coil and rotor. NOPE. They give the car back and now she starts fine...just idling rough and at like 1.1k, and has been running that way since.
Problem #2I dont even know whats going on here. Is this a fuel dist./pressure issue? Ignition issue?(I assume not, got a spark on all four and dist cap was fine) MAF? Has anyone ever experienced this or have any ideas?
Thanks for reading and any input.
