TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Thu Nov 20, 2003 10:41 am
A good way to check the thermo, is if the top hose is really hot, and the bottom one where the thermo. is behind is cold, then you know it's your thermostat. You know your thermo. isn't opening and letting the coolant/water run through the radiator to be cooled again. Thats what happened with mine a while back, and it's a real easy job to do.
