I went to the track on Tuesday to squeeze in some runs with the new mods before it closes for the winter. I have recently got the car running after doing t3/to4e 50 trim, sard 720cc injectors, custom fmic, custom piping, custom downpipe, emanage, ecu chip by Carl H, Q45 maf w/ Stillen pop charger, Tomie 260* 8.8 cams, Tomie springs, and port and polish. It was like watching the John Force crash from the inside, except the only thing wrecked at the end of the night was my ego. It was ugly! If it wasn't bogging down, I was spinning the tires like I was on ice. Once the motor got hot it would want to lean out and stall a idle. Tapping the gas was the only way to keep it running. I also noticed the boost would go all the way up to 15psi when the turbo spooled all the way up and then bleed down to 10 if I held the gear. I was launching around 5000rpms, anything less and I would end up no where near boost. My best run of the night was a 14.6 @ 97.8, which is down from my best run last year with the stock motor. That was a
[email protected]. I'm thinking some of it has to do with the tune and alot has to do with the driver. Looks like it's time to admit when I'm out of my leage and get a tuner and some dyno time.
