Dano »
https://forums.nicoclub.com/dano-u2493.html
Thu Feb 19, 2004 12:59 pm
I did a compression test on my car as well as my buddy's S14 today, i've suspected my #2 cylinder has had a problem for a while to checked the compression/pulled the plugs...
the spark plug for cylinder two was definately heated around the whole plug vs. the others, i have NGK platinum Rs (factory) and under 1k on em. the metal portion of 1,3,4 is greenish whereas the #2 has a pink tint...u can tell its been heated.
here's wat came up for compression numbers.
Cyl: tests, if more than one, the cylinder was tested again.
1: 155, 1552: 75, 135, 150, 145, 1503: 145, 1454: 150, 150
any insight on the culprit, i figure the valves may needed more oil from the first test... but could it just be a bad headgasket? any insight would help. Thanks in advance.
-Dan
