buddha »
https://forums.nicoclub.com/buddha-u42858.html
Fri Sep 22, 2006 7:40 pm
So my car started to run like crap. I check all the coilpacks first unplugging one by one, turns out cyl #1.was not firing. But heres the weird thing, i swap coilpack coil #1 with coilpack #2, and #1 still dosent work. so i change the plug. still nothing. I check the wires in the harness, nothing seems to be wrong. I test for power coming to coilpack #2, and the two wires on the side dont show power, and the center one does, so i then check #1 and it has the same, power to the middle, and nothing to either side. i cant figure it out.
is there a different way to test the coil? has anyone ran into this problem before?
