Bad Clutch Problem (PLEASE HELP)
jasonrps13jdmdrift
Car: 1990 240sx
I have a 1990 ka24e 240sx and i just put my 4th clutch in june i dont think that the car should be doing this........... but every time i replace the clutch it is the same problem... the throwout bearing ......... its just a replacement deal from advance auto but it shouldnt go out like that and the last one i took out was cut open on the flywheel side..... plus now its broke down because the seal in the slave cylinder went out and siezed up the clutch fork ....no worries i may be a newbie but i wasnt dumb enough to take it out of gear.... please give me any info you can
240marcuSX
Car: E34 525i
E46 M3
quit buying cheap junk. You said youve replaced the clutch 4 times now!?
you could have done it right a couple times now in the time that it took you to do it cheaply 4 times!
get: a GOOD clutch, factory T/O bearing, factory clutch fork (and springs), factory slave cylinder,
Get a new flywheel, or get your current one machined, and install all listed parts, or get a mechanic to do it.
