jwallan »
https://forums.nicoclub.com/jwallan-u51001.html
Tue Aug 04, 2009 4:50 pm
I recently installed new brake lines to the rear and when bleeding the brake system I forgot to remove the electrical connectors at the actuator for the DPV anti-lock braking system. Since then I am now blowing the 10 amp fuse for the radiator fan system, air conditioner, ascd, time control unit, anti-lock braking system and also melting the 30 amp green fuse link having the white lead going to the SMJ and the other white lead going to the battery and charging system. After they blow you can hear the circuit breakers clicking away and the auto air system, all power windows, door locks, trunk release won't operate and the key gets locked in the ignition. Is it coincidental that the electrical problem was caused by the anti-lock brake system? If anyone can help fix this problem or shed some light as to where I should go next would be very much appreciated.
Just wondering if anyone has any suggestions re:above?
Modified by jwallan at 6:34 AM 8/29/2009
