Bad Chain Tensioner?
newdude1
To I was setting my timing and I removed my tensioner in the process. Now after reinstalling it the chain is slack. Here are before and after pictures.Before:After:Its almost like its not strong enough to spring back like a notch or two now. Should I replace it? I unistalled it then reinstalled it and its still the same.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
I have a brand new one sitting in front of me that i dont need if you want it you can send me like $50 to paypal and ill ship it out today [email protected] is the paypal address.
I mean if you took it out i would replace it just my opinion though.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I wouldn't worry about it. Most of the pressure from the tensioner is from oil when the engine is running. I'm also assuming that that is right after you set the cam timing, and before you turned the engine over at all?
newdude1
I set the timing then reinstalled the tensioner then rotated it and every time it hits tdc its slack.
newdude1
Is there a way to manually make the tensioner tighter?
Also just now I was rotating the motor a few rotations and notice something weird. Everytime I hit tdc the chain would be tight but then I could watch it slowly droop down. What ever could cause that I think is my problem. But I dont know what would cause that.
Modified by newdude1 at 8:44 AM 9/14/2009
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
The tensioner is oil pressure based. It will go away after you start the car. The slack comes in from the valve springs pushing back on the cams
