Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Thu Aug 26, 2004 3:42 am
I just went through the servcie history on the car.
Interesting read.
The car was purchased from Frontier Infiniti, September 1, 1997. It was an off-lease car, with 45,000 miles on it.
Ground wire added to MAF in November, 1998 at 61,000 miles.
Tony had the injectors replaced in March, 2001. #7 faoled, and he had all 8 replaced. 74,000 miles.
The MAF was replace in September, 2001 at 76,500 miles.
Fuel pump, controller, filter and relay replaced in August, 2003 at 90,000 miles.
Plugs and Fuel Pressure Regulator replaced in September, 2003 at 90,500 miles. I think they are Bosch (I know - I am getting new NGK's tomorrow).
Water Pump, hoses, thermostat, Battery, Brakes, Rocker Cover gaskets, PS lines, etc. in December, 2003 at 92,000 miles.
Regular 3,750 service, 7,500 service, 60,000 service, and 30,000 mile service at 90,000 miles. Synthetic engine and transmission fluids. Brake, PS, and water system flused regularly.
The car seems to be well servcied.
The Knock Sensors gave a code, on the ECU, at 90,000 miles, but were not replaced, because the code did not return. Fuel Pump replacement fixed the problem. The car overheated at 92,000 miles, when the water pump was replaced. Tony did not let the car go very far, when the temp gage went up. He had it towed. The KS's did not code again.
I kind a think it is the plugs AND the Knock sensors.
IF I can get the plugs next week, I can replace them, then, get it to T3, for a consult, and see if Dennis will test drive it.
It's too bad they didn't replace the KS, when they had the plenum off, to replace the fuel regulator.
