Bad Calipers?
le_ryan
Car: Mazda3
91 Nissan 240SX SR
i cant seem to get my rear calipers to collaps so i can install new pads.iv'e drained all the fluid, they are off the car, i tred to collaps them with plyers (big ones) , ive done brakes plenty of times, and always able to get them to collaps.Note: i had the rear jacked up and car in gear and running, so the tires were spinning, but when i held the brakes the rear still spun.....?So i guess they are bad?
Nick240sx
Car: 2009 Ford Fusion SE Sport
they are seized, it most likely a 240 problem samething happened to mine, the pads just sat there and the caliper didnt close or anything
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
You have to rotate the caliper piston to collapse it back into the cylinder. They make a special socket tool for it. It looks like a disc with to prongs comming out of it that you can attach on any socket wrench. I picked mine up at pepboys.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
Sweet!, i got them to collaps but im wondering if they are still bad,Note: i had the rear jacked up and car in gear and running, so the tires were spinning, but when i held the brakes the rear still spun.....?would this indicate they are blown? Plus the boot on the piston is gone.
If i work the E-brake linkage the pistons extend...
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Typically when the calipers go bad they seize in the "on" position and squeal like hell. I hate buying calipers. I had to on my car because they were so locked up that there was no getting them apart to rebuild them.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
While changing my rear pads recently on the S13, both calipers died when we opened them.
I just got a complete set of 4 rebuilt calipers from a member on here for $125 shipped, deal of the century.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
One of my ****ing rear calipers was jammed when i did my Z brake swap, i just went to a j-yard and pulled one that wasnt so rusted.
