alpalwal »
https://forums.nicoclub.com/alpalwal-u28394.html
Tue Nov 28, 2006 9:14 pm
A month or so ago I did a bunch of work on my car... I put in a new motor, put on new brake pads, rotors, and stainless lines all the way around....
since then, the brakes have completely sucked.
If I start the car with my foot already on the brake pedal, the pedal doesn't move in at all which leads me to believe there is a problem with the brake booster.
I have 2 check valves in by brake booster line right now, and both allow vaccuum from the engine to flow and pull air from the brake booster..
I have no idea what else my problem can be besides a spontaneously bad brake booster.. any other suggestions of tests or parts I need to fix?
89 240 with ka-t and non abs.
