notacomputergeek »
https://forums.nicoclub.com/notacomputergeek-u289265.html
Thu Apr 11, 2019 12:34 pm
I have a 2004 Nissan Quest that needed a new transmission mount. Everything listed next was working fine before I started working on it. When I finished and started to test drive it, the following things don't work anymore: Display Unit, A/C & Heating controls, and radio controls. The check engine light had been on before I started, so I took the van to a parts store to pull the codes. They tried 2 different OBD II devices and neither could pull the codes. The second device acted like the car wasn't even on, even though the key was. I took the van to a second parts store and they couldn't pull the codes and said it wasn't even connecting to the car, so I assume the port is bad too. An interesting thing happened while working on the van: I forgot to disconnect the battery before starting to work and when my wrench hit the transmission, I saw a spark. I disconnected the battery and finished the job. I've checked continuity on all the fuses and they all check out fine.
What should I check next? What could have caused these things to go out and how can I fix it?
Thanks for your feedback.
